bjrrockwell
- Jun 18, 2011
- 49
Took boat out for first trip today of year. While backing boat off must of sheared a pin on rollers and roller fell off, and took a decent piece of hull with it. I figured this is a sign and plan replacing all 24 however Cox has been out of business for some time. Rollers have following dimensions 3 inch width, 4 inch height, 3/4 inch inside diameter, and it appears 2 inch inside width however tough to tell with spacer inside and washers. I'm unfamiliar. I measured the marked area on bared shaft and it appears roller and washers covered 2 1/4 inches but I noticed the others also have a spacer on the inside. Looking for any advice. Also when I go to replace all the rollers it would be easiest to do it with boat off trailer just trying to figure out logistics as local lake enforcement will frown on me doing it in parking lot with boat in the water. Thank you.
