Re: Looking for sway controller for trailer with surge brakes
Do you NEED Sway Control because you are swaying?
Or do you WANT Sway Control because you never want to experience it?
There is no reason to have a sway problem with a properly loaded trailer.
Every trailer will sway when the critical speed is exceeded.
That speed is normally well above what you will ever experience. (>100mph)
No Mechanical Sway Controller can be used with surge brakes.
Mechanical Sway Controllers operate by stopping the truck and trailer from moving relative to each other.
Surge brakes operate by sliding back and forth.
The sway controller wound prevent the brakes from working.
There are some high end aftermarket, and
Vehicle Integrated Electrical Sway Controllers that apply the trailer brakes electrically.
Adding "
Electric Over Hydraulic" control would allow this type of sway control to work.
Actually going to "Electric Over Hydraulic" would allow the Mechanical Sway Control to work also.
