If you ever walk across the launch zone of a drag strip you will immediately notice that it is nothing like a public road.
It is so sticky you will almost walk out of your shoes.
The amount of traction IS dependent of the area of contact when Glue is involved.
The friction Formula
F= u x N
Where:
F = Force of Friction
u = Coefficient of Friction
N = Force Normal to the surface. (Weight/Load)
Notice that area is not part of the equation.
There
3 laws of friction are:
1. The force of friction is directly proportional to the applied load. (Amonton's 1st Law)
2.
The force of friction is independent of the apparent area of contact. (Amonton's 2nd Law)
3. Kinetic friction is independent of the sliding velocity. (Coulomb's Law)
Friction is counter intuitive.
Watch This!
A brick, a block of wood, or even a sheet of plywood will have the same amount of friction no matter which edge or face you place on the bottom and drag across the driveway.
Yes, an empty trailer will be easier to drag with locked brakes than a loaded trailer.
Not because the tires are flattened less, but because it weights less.
