WaterDR
- May 8, 2012
- 730
I have a 2010 Triton Scissor Lift Trailer. I have a 2007 Chrysler Pacifica. All lights work, but not the running lights or the tail lights and I can't figure this puppy out.
This is what I know and what has been done:
1 - I replaced the 4 pin connector on the car.
2 - Pins on the trailer connector are clean and free of debris.
3 - There does not appear to be any fuses on the car or on the tailer.
4 - I assume I have a good ground since some lights do work.
5 - The car has a wire harness kit that is two years old. It is a y-harness with a black box. I have checked all connections to the tail lights. All seems fine.
6 - When I plugged my car into another trailer, it did the same thing indicating to me that the problem is not the trailer, but teh car.
7 - I bought a 4 pin connector with the LEDs. When I plug it in, the tail light, light comes on. In fact, it is on no matter if the tail lights are on or off. Even with the tail lights on the car off and the car not running, the indicator still lights red. Makes no sense. The other indicators flash appropriately.
My only option at this point is to try hooking up my Jeep to the trailer and see what happens. And/or replacing the $120 wiring kit on the Pacifica.
Anyone have any thoughts?
