Re: transom saver question
I am not a proponent of deflopperizers in the first place and they certainly don't save transoms. But if you must, the "bend down and reach under" devices really can't serve any useful purpose at all, especially a long reach.
There are four purposes:
1. Keep the motor up so it doesn't drag the pavement or hit bumps.
2. Keep the motor from flopping side to side
3. Keep the motor from bouncing on whatever it's held up by.
4. Keep a transom that's too weak and rotten to support an outboard from cracking off and seperating from the boat, by transferring whatever forces there are from a weak transom to a weak trailer strut.
Solutions:
1. the factory installed tilt lock--they don't fail except perhaps small old motors bouncing way up, sprniging the latch, coming down.
OR
1. a block of wood up in there
2. If your steering it that loose, tie the motor off. This is more of a problem when trailering a motor down.
3. Tie the motor down so it's firm against whatever you use, be it tilt lock, block or commercial deflopperizer.
4. Repair boat; it's not seaworthy. This one is only a problem with weak transoms; a transom in good condition is not affected by the outboard hanging on there.
