Re: How to make a transom saver
When I reconditioned my grandfather's old row boat and bought a small outboard for it, I had no clue about the differences between a short- or longshaft O/B. As a consequence, I needed a transom saver. Being too cheap to buy one, I made one myself for less than $10. I measured and cut a section of 1in square tube steel (about 2ft in length), then measured and cut two pieces of 2in angle iron (about 3in wide) for welding onto each end of the square bar. Since one end would be resting up against the roller on the trailer, I left it alone. The other end would be resting against the lower unit, so I wanted to protect it. You can dip this end into liquid rubber, or use some heavy rubber to line it (I cut up a thick inner tube). Paint it any color you want, but black suited me just fine. Never had a single issue with it, and gave it to the fella that bought the boat years later.
