Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Thinking about installing an ez loader swing tongue kit
This topic is closed.
  • Thinking about installing an ez loader swing tongue kit
    The EZloader that came under my new Islander 221 doesn't have a swing tongue.
    The kit is around $500 in Canada and I was thinking about installing one to lessen the length.
    Has anyone heard of any issues regarding the swing tongue EZloader kit? I remember year ago there was some kind of recall for washers but I can't exactly remember if it was a real safety issue.
    Re: Thinking about installing an ez loader swing tongue kit
    If it is like the factory installed ez loader folding tongue... they work great. My buddy has one and its a good solid unit. No issues. That being said... there are many other cheaper options.
    Post #27 & 35 pics of what i installed on my trailer... $59 and some time. Plus paint, etc... but i think it looks factory.
    http://forums.iboats.com/showthread....folding+tongue
    Here's an easier... more for the weekend DIY'r. It's a bolt on job
    http://www.iboats.com/Fulton-Fold-Aw...view_id.275504
    Post a pic of your tongue and people will get you a number of different options. Hope this helps.
    1990 Stingray 536ZPX 4.3 Mercruiser - SOLD
    2001 Glastron GX185 4.3 Mercruiser - SOLD
    2012 Yamaha SX190 1.8L Jet Boat
    Tow rig - 2013 Silverado 2500HD Duramax
    • #3
      Did you come up with anything yet??
      • #4
        The hard ware that EZ loader uses iis made by Fulton
        You can buy it dirrect from fulton
        There web sight has instructions
        Looks like the hardest part is making a straight cut on the frame
        Harry
        • #5
          Here is a link with pictures regarding the installation of the swing away tongue for my trailer, hope its helps.
          1993 Glastron SSV190
          Deck Restoratiion
          Swing Away Tongue
          Transom Restoration
          13 X 21 Stiletto SS Prop
          Trailer Crossmember Repair
          • #6
            That's a great looking installation and a perfect solution where parking space is tight. I have no experience with the swing away tongue, but one of our local fishing sites has several posts from members that have had problems with the bolt or pin shearing. They all recommend pulling the pin and bolt regularly to check for problems and always carry a spare of each on board.
            • #7
              This one has been installed for 2 1/2 years now, a lot miles on road without problems. Up to day still like the first day.
              Deck Restoratiion
              Swing Away Tongue
              Transom Restoration
              • #8
                I contacted ezloader again and the kit is complete with new brake lines and will retain my warranty.
                I am just waiting until I finally get my new boat home so I can unwrap her and a look at the trailer to make sure I am getting exactly what I need.
                There is no cutting or welding. The kit replaces the entire forward section and includes the swing tongue already set up. Its just a matter of unbolting one and installing the other.
                • #9
                  Could you provide apicture of the kit you just mentioned here? Model and or part number, would like to seethat one.
                  Deck Restoratiion
                  Swing Away Tongue
                  Transom Restoration
                  • #10
                    Its in my office email and I will do just that next week.
                    Looks simple to install, but I want to make sure I can do I can do it with the boat on the trailer. But I can always take tools to the lake and I sure I could convince a buddy to take the Islander fishing for the morning
                    • #11
                      This may not work but here it is.SWing Tongue Kit.pdf
                      • #12
                        So that's $500? Seems pretty expensive. The folding portion looks exactly like my $59 unit i installed on my trailer...whatever works for ya tho. Click image for larger version
ID:	105551Click image for larger version
ID:	107192Click image for larger version
                        I suppose since you are getting brand new, it would be hard to cut and weld on the trailer. And if you need to have a warranty, then use their provided kit
                        • #13
                          It does seem expensive and I own three welders!
                          But it includes the brake lines and small parts and it retains the warranty on the new trailer. And it comes painted to match.
                          I need to do some measuring when I bring it home. The boat may be to tall to fit inside my 8ft garage door.
                          • #14
                            90stingray...... do you have a make and model or part number for the hinge you used??? That is the exact application I need.
                            • #15
                              This is a 5 1/2 year old thread and stingray hasn't been here in 6 months.
                              Closed.
                              BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
                              Please, no PM's (Private Messages) regarding boat/engine problems.
                              That is what the forums are for.
                              Only forum/moderator issues will be answered in PM's.
