Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
Regular trailer for pontoon use?
  • Regular trailer for pontoon use?
    Sorry if this has been addressed but I couldn't find a reference to it: I just put my new-to-me Thundercraft 1750 into the water, but my waterfront is too crowded with the 16-6 pontoon. I have to move the toon to the cottage as the family is demanding its return! The trailer that came with the T-craft has bunks that are raised about a foot to account for the deep V hull but they are adjustable.
    I have no experience or familiarity with boat trailers. I would like to adapt the trailer to be able to load and unload the pontoon for this task. Is it possible to do that? Might the pontoons simply rest on the bunks as-is? The pontoon is only 6 feet keel-to-keel.
    1990 Thundercraft 1750 LS
    Re: Regular trailer for pontoon use?
    I measured the trailer and the distance between the bunks is 3 ft 7 in. IIRC I saw an example of a pontoon on a boat trailer where the guy had lashed 4x4 beams across the trailer and attached lumber bunks to the beams . . . looked very Beverly Hillbilly, but still . . . he's the trailer|:
    • #3
      More searching shows that this question has been asked in the past and the reply was in the negative. I will reconsider.
      • #4
        yep... without extensive rework of the trailer, its not going to happen. Pontoon trailers are fairly specialized.
        • #5
          A flat bed car hauler trailer on the other hand could work pretty well as long as you can keep the toons off the fenders
          Kevin
          Originally posted by Tinnie
          But, where are the reevets?
          1981 Wellcraft V-20 CC Fisherman (FREE BOAT)
          1989 Wellcraft Monte Carlo 28(Build thread here)
          1992 Hotsports Jet'n'Cat Yam 701 WR3 drivetrain "SS George Washington"
          90's Yamaha WRIII and a pair of 95 Kawasaki ZXI-900's
          Fresh clean cheap oil is better then old dirty expensive oil any day
          sigpic
          • #6
            Might be able to work something out with the local marina, especially if you have a relationship with one.
            Better to have it and not need it than to need it and not have it.
            21' Suntracker(for my girls), 16' Polarkraft MV w/ 25 HP Merc(for me), 14' Odyssey bucket raft, 16' Purple Mad River Explorer; vice-admiral's boat, but she lets me use it as long as I don't forget it's hers. Esquif Vertige
            • #7
              Most boat dealers that also sell pontoons will very likely rent a pontoon trailer as will many marinas. Do this safely.
              • #8
                Right . . . I'm convinced. The problem seems to be that there are no trailers around my area that can load such a narrow pontoon spread (6 ft.) I may just try harder to sell it locally and pass the cash back to the cottage crew . . .
