Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Auto bow eye catch, is there such a thing?
  • Auto bow eye catch, is there such a thing?
    Does anyone know if there is an auto bow eye catch that locks on the eye as you drive the boat on the trailer and into it? This way one person can load his boat and not have to put the wrinch on it untill the boat is in the parking lot.
    Re: Auto bow eye catch, is there such a thing?
    Sure, right here. However, from what I've read in threads here, they don't always work that well.
    Bob, Seneca Lake NY
    '88 Bayliner 1700 Capri bowrider, 85 HP Force O/B, "Sea Weasel"
    '94 Grumman Fish'N Fun pontoon, 40 HP Merc
    Want a vessel safety check? Click here. Want to join the Coast Guard Auxiliary? Click here.
    Disclaimer: Although I am a member of the USCG Auxiliary, the opinions and advice in my replies are my own and do not necessarily reflect CG or CG Auxiliary policy or regulations unless so specified.
    • #3
      Yep- here http://www.pacifictrailers.com/KODIA...g-System-BB-2/
      Don't use it if you have a cast bow eye- it can shatter it.
      • #4
        Oh- you beat me to it. lOL
        • #5
          Someone is gonna say it, so it might as well be me. Call me a purist, but you could not tear up the ramp and just load correctly.
          Just saying.
          Bill
          • #6
            ******* also sells them - but as Splat eluded to - if you go this route, be prepared to catch alot of flack from some launches, and possibly be kicked out of other ones. This would definitely fall under the heading of power loading.
            Jon Hunter
            Marion, NY
            2006 Procraft 200 Combo with Merc 200 Opti
            2007 Homemade Duck Boat with Merc 39
            • #7
              I made my own. I'll try my best to explain how I did it. I started by making a steel plate. Mine is about 16" long. The bottom has a piece of 5/16 tubing (ID) welded to it. I used a 5/16" piece of round stock and fastened it to the trailer in such a way that the plate could swing back and forth, forward and backward. The plate is about 2" wide and is made from 1/4" Steel as I recall. I cut a slot in the plate so that it could slide over the eye as the boat comes up on the trailer. I then mounted a small hydraulic arm, the kind that holds up trunk lids. The bottom end mounts to the trailer several inches forward of where the plate pivots. The top end is attached to the plate. When the hydraulic arm is extended, it forces the arm almost upright. I have a small chain mounted so it limits the travel. As you drive the boat up on the trailer, the bow eye comes in contact with the plate. As the trailer moves forward, it comes to the point where the slot in the plate slips over the bow eye. At that point the hydraulic arm pressure has forced the plate up against the boat with the eye in the slot. Boat is then locked in place. When its time to put the boat back in the water, I pull the plate down away from they eye and again have a small piece of chain that clips on it and holds it away from the eye, so the boat will float off the trailer.
              I'm really making this sound way more complicated then it is. The thing works perfectly and I've been dumping my ski centurian in the water for about 15 years with zero problems. Its pretty fool proof. I don't have any sort of winch. I can probably figure out how to post a picture if someone is interested.
              • #8
                Originally posted by ctjstr View Post
                I made my own. I'll try my best to explain how I did it...
                ... I can probably figure out how to post a picture if someone is interested.
                Yep, a pic is worth a thousand words LOL
                • #9
                  There's also this one: http://www.snapperboatlatch.com/
                  I bought this one a couple years ago and tried it on my '98 Four Winns 278 Vista, which weighs in at 9,600lbs (not including trailer) and it didn't work very well. The servo is not strong enough to release the latch if the bow eye happens to be tight against the latch mechanism. However for smaller boats, used as in their demo video, it would work pretty well.
                  I'm in the process of developing one to handle my boat's weight and it's similar to ctjstr's, but uses a remote controlled electric winch to draw the bow tight against the bow roller to eliminate the excess movement that I had with the other latch. All the other one did was tear up the bow eye from moving up and down (trailer flexing) while pulling up the ramp. My latch mechanism is also easily removable with one pin so that on "No Powerloading" ramps, the winch could be used by itself.
                  USCG 50 Ton Master Inland/OUPV Endorsement+Towing
                  1998 Four Winns 278 Vista w/twin 4.3GL, 4KW Gen
                  1999 Yamaha Waverunner SUV
                  2003 Yamaha Waverunner SUV w/MR-1 four stroke conversion
                  • #10
                    I used a 'boat buddy' with my 23' jetboat and loved it. We generally loaded non-powered and it still helped quite a bit.
                    1978 Glastron/Carlson CV23
                    429/Berkeley JE
                    • #11
                      Wouldn't trust it. Winch strap and safety chain.
                      Safe and happy boating always!!!,
                      Veritas Honus
                      1992 Chaparral 2050 SLC: 205HP 4.3L Yamaha I/O
                      ShoreLand'r tandem axle trailer
                      T/V: 2001 Dodge Ram 1500Sport 5.9L 4X4 Off Road Package Dana 410 rear
                      Fear is only a state of mind. Gravity is a fact of life...
                      No fall, however high, ever hurt anyone... It's that sudden stop at the end...
                      • #12
                        Just saying.
                        Bill
                        Gotta agree here....I load and unload by myself all the time. Never needed an autolatch.
                        A good brand of engine is one that runs
                        • #13
                          when I pull up to a loading dock I have my wife throw me a line that is hooked to an eye bolt that is mounted on the very front center of my pontoon boat. so after I get the trailer into the water I just pull the boat by hand to my trailer strap.This way I don't get so wet. I have boat guides on the rear and two in the center in the middle of the trailer.Once I fit between the two rear guides it's easy loading .
                          • #14
                            I have slight problem when I have to do it by myself. 1) I have a bad back(6 surgeries) 2) the trailer has rollers 3) boat is a 24 footer and very heavy (approx 4000lbs) to handle. If you have ever tried to load a big boat onto a roller trailer you will very quickly learn that what goes up ALWAYS rolls back down. So with the auto lock I figure at least I will have a fighting chance of the boat staying on trailer long enough for me to get everything into the lot to fasten it down safely for the road trip.
                            Does that make any sence to anyone but me?
                            • #15
                              just a thought, but put ur trailer in the water deeper, then pull ur winch strap down to the eye bolt and winch away. if ur deep enough it should be that bad. i guess it depends on the pitch of the ramp tho. ours is fairly mellow. bow is probably 2 feet away from bow roller on the trailer.
                              1988 Wellcraft 170 classic
                              1985 140 3.0L mercruiser
                              alpha 1 gen 1
                              http://forums.iboats.com/showthread.php? I NEED HELP!!! any is better than none
