Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
wheel fell off while towing, what do I do??
  • wheel fell off while towing, what do I do??
    Hey there, Just got this boat and yesterday while getting it home from my storage lot after my first time using it. While almost home a wheel and hub fell off, the inner bearing looks good, while the outer bearing is no longer existant, and there is a pretty bad gas in the spindle, not deep enough to effect strenght at all, but definitly there. My question is what do I do about this, there is this stuff I have called locktite liquid metal miata owners use to repair broken keyways on crankshafts, can I use this to fill in the score then put on new bearings? I've never replaced bearings before
    Brian
    sigpic
    1989 Bayliner Capri OMC 3.0
    1978 Wellcraft Nova 210XL W/ Merc 233 (Ford 351W with 4 barrel holley) , work in progress
    Re: wheel fell off while towing, what do I do??
    How much for a spindle?
    1971 gregor 9.9 14 foot
    2009 tracker 1754cc 40hp merc
    • #3
      I don't think you can repair a spindle with any sort of liquid metal. If it's damaged wher the bearing rides, it must be replaced.
      I suggest you do some Internet research on trailer bearing replacement. You will find articles with instructions and photos.
      Is the trailer home or sitting by the side of the road? Here is something that can get your trailer home:
      http://airtighthubs.com/products-e-axle.php
      Here is an article that might get you started:
      http://origin-videos.trailerboats.co...&sectionid=318
      Ron
      2000 Camano Troll
      North Charleston, SC
      • #4
        You will be pleased to know that trailer parts are pretty cheap. Heck you can get a whole new 3500lb axle complete with new hubs for $130 from Tractor Supply, Northern Tool, etc etc. It's definitely not worth trying to repair most trailer running gear parts.
        You have just experienced the worst case scenario of what can happen if you don't maintain your bearings. Although I have done the same thing just trying to get a new-to-me rig home. My buddy and I had to take the front two wheels off a dual axle trailer in order to make it home due to a hub totally blowing out just like yours did.
        1976 18' Starcraft SuperSport 90HP Evinrude
        Restoration thread http://forums.iboats.com/showthread.php?t=357767
        1966 16' Starcraft Jupiter 85HP Johnson
        Restoration thread http://forums.iboats.com/showthread.php?t=338633 sold
        • #5
          You got real lucky. Get a loto ticket.
          • #6
            I agree, your very lucky, I have seen this happen and cause far worse things happen to the tow vehicle as well as the occupants of the tow vehicle.
            When I worked in the RV business and this type of situation happened, we would not repair the spindle, we always replaced the axle that way any unseen damage was taken care of.
            Of course it depends on where the boat and trailer are sitting, if at home, jack it up and get a new axle with hubs for it, replace and have the piece of mind, if sitting on the side of the road, it is probably best to have a roll back pick it up and take it home for you and then get a new axle and replace it. Besides any surface damage to the spindle, I would be pretty sure that it has bent the spindle as well, even if not apparent...
            Unless you are lucky and it has a bolt on spindle, welding a new spindle on, takes some skill as well as being able to make sure it is straight, they use jigs in a factory to ensure straightness...
            In the future, when you buy a trailer or anything on the trailer, it is prudent to jack it up, and check the bearings before attempting to take it home, I do this on boats, travel trailer, utility trailers, etc. It really does not take that long and it sure can save you a world of heat ache..
            Again, glad your okay, and you just have to deal with a wheel falling off.
            Dave
            • #7
              If the spindle is not bent, the spindle nut threads are good or can be filed so that the nut will thread back on and the inner seal suface is not buggered up...................................
              A gouge or two on the other surfaces of the spindle are nothing to worry about.
              The bearings are not running on the spindle, the inner races of the bearings are on the spndle. You might have to file the gouge if it is where the bearing resides in order to get the bearings to go onto the spindle.
              That is what I would do. Not necessarily what you should do.
              • #8
                Alright thanks a million for the advice guys, after reading thru this I went to a local trailer shop, and they can give me an axle for around $180, plus $70 for new brakes, just gotta take the axle off for them to match it up. I only had about 2 miles to go till I was home when a lady honked her horn and said I was losing a wheel, it was when I pulled into a hotel parking lot that the wheel then busted off, somehow the other dry rotted tire held up for the 2 miles until I was home, my dad was supprised that the other tire didnt blow from the added weight and cause the boat to tip over. Will make sure to check all the bearings next time I buy any sort of trailer
                Brian
                sigpic
                • #9
                  if the tires are dry rotted then you might want to get new tires as well.
                  Back to Top
