I have an older Four Winns single axle trailer that has a removeable tongue with surge brake mechanism. There doesn't appear to be any pressure in the surge brake, thus causing the coupler to slam forward when I am braking. I have been told this may be because of water/rust in the brake lines or master cylinder over time. I do not like this type of moving mechanism at all. Can this be replaced with a tongue/coupler that does not move/pivot over the hitch ball? Should I attempt to repair the surge brake? If I replace the trailer tongue/coupler with another one I assume I will lose the trailer brakes, although they are not working now. Ant recommendations as to what to replace this with? Thanks in advance for your time.
