Re: rubber seasense roller slides off bushing and over roller arm, can i glue it?
Yes they are not the exact replacement, I can't find moeller rollers with a 3/4 shaft and the inside bushing length less than 1 1/4 i have called several manufacturers and talked to the tech support at easternmarine.com the trailer parts superstore. They no longer make a direct fit, soooo I did what many people did when they were younger and didn't have money for brand new things, they modified old things to work in a particular application. I became fairly proficient at this, but back to my current problem. The glue would only glue the bushing to the rubber roller, not the aluminum support arm that it rides on. My latest and greatest idea is to have someone punch some 18 guage sheetmetal to make very thin washers that will be installed behind the roller on the tapered aluminum arm and prevent the bushing from sliding through the rubber roller. By the way I bought seasense rollers from iboats. I had actually called seasense the manufacturer and they said the inside length of the bushing was less than one inch but its actually about 1 3/8". You can even be mislead my the manufacturer.
