Re: Ball mount ex-tender
Would another foot of hitch length keep you from getting your feet wet?
Yes those would work....for your short distance to the ramp.
As an alternative, consider this method:
If your alone, tie a length of line from the winch post on the trailer, to a cleat or the boweye on the boat.....let your vehicle/boat roll back down the ramp freely (not the full length of the ramp mind you, but just enough to get some good inertia on the "pop") , until your trucks back tires are just touching the water.
Then "pop" the brakes and the boat should just slide right off the trailer.
Get out of your truck, and if you don't want to get your feet wet, climb up into the truck bed and over the tailgate to stand on the trailer tongue or hitch.....grab the line and pull your boat in.
(if you have a camper...your SOL on getting into the truck bed)
If someone is in the boat and your backing the truck down, omit the line to the hitch post and just "pop" em off the trailer......you don't even have to get out of the truck.
As a safety precaution, stop the boat half way down the ramp and undo the safety chain and winch strap to make sure your boat is not going to slide off on it's own. That is highly unlikely to happen, but check it first before you go rolling down the ramp with the boat not secured to the trailer.
