Re: ShoreLander Trailers - Any Problems?
Had one on a new rig in 1997.
Painted, roller trailer, 1800# capacity, carrying a load of 1400# max.
The popular ShoreLandr wishbone style trailer with the rear crossmember that pivots.
Boat was used for a 1600 mile vacation each year, 200 miles of which was on gravel roads.
1997, bow roller split in half, keel roller broke.
1998, bow roller and both keel rollers broke. And the tongue developed a crack just aft of the winch post.
Found out that the rollers were defective and had been recalled, but the dealer kept replacing them at our cost.... till we found out.
1999, fender bracket cracked through, and the rear crossmember bolt sheared, causing the crossmember and roller assembly to fall to the road resulting in the boat hull being punctured, 2" x 2" gash. End of fishing trip - 10 days early.
We have seen this same exact failure on 2 other trailers, and have been told of several others by the repair shop.
2000, no problems.
2001, not used.
2002, Rear crossmember bolt again shear, resulting in a 1" x 6" cut in the hull.
The trailer was thrown away, junked.
Bought a new Karavan, has seen almost twice the use per year, ZERO problems over the last 7 years.
