Re: no tail lights.....why?
Corrosion is most common problem either in the socket, or where the common ground goes from the socket to the frame of trailer, I found that the trailer mfr. had used steel terminals on the grounds and they had corroded and were not making <br />contact with the frame. These type problems are most common, but if the stops work, bay be bulb or socket.
