Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Trailer Weight
  • Trailer Weight
    Trying to figure out the total weight of a boat and trailer that I'm looking at buying. I know that the gross weight of the boat is 3,900 lbs but I', not sure about the weight of the trailer. It is a double axle trailer with surge brakes. My guess is that it the trailer must weight approx 500 lbs. Does this sound about right for the weight of the trailer? Your assistance on the trailer weight would be appreciated.
    Re: Trailer Weight
    Probably more than that, go to a couple of trailer sites, like Loadrite, they give weights of their trailers. www.loadrite.comI think a single for a 19' weighs about 575, so a tandem will be closer to or over 700.
    1988 Four Winns 200 Horizon
    4.3 OMC Cobra
    98 Jeep Grand Cherokee 4.0 Selectrac
    07 Jeep Grand Cherokee Limited 5.7 Quadradrive II
    "While air doesn't freeze....rust never sleeps"
    • #3
      Re: Trailer Weight
      That sounds Light for a tandem trailer.....Just the Axles,+ Springs weigh about 1/2 of that......I'd think 1000lbs would be Closer........
      • #4
        Re: Trailer Weight
        Your're right Bondo, I checked and the lightest tandems are about 1000 lbs...
        4.3 OMC Cobra
        • #5
          Re: Trailer Weight
          I have a #4500 Load-Rite tandem axle and the ID plate states 1250 lbs.
          • #6
            Re: Trailer Weight
            My tandem axle Venture trailer is about 1200 lb.The only way to really tell is to have the combination weighed. You can do this at a public scale. truck scale, recycling center, junk yard, etc.
            Ron
            2000 Camano Troll
            North Charleston, SC
            • #7
              Re: Trailer Weight
              The big question is what is the trailer made out of ? If it is steel it will be quite a bit heavier than aluminum. Also, does it have torsion axles or leaf-spring suspension ? I have a triple axle aluminum 34 foot trailer with torsion axles that weighs 900 lbs, it is rated at 10,500 gvw. I also have a 36 foot steel triple axle with leaf springs that weighs 2000 lbs, that will carry 18,000 lbs.
              Back to Top
