1975 shorelander
ckremer
i recieved a boat from my father he had an old lund he gave me his trailer and a 16' sylvan, the boat is a little wider than the 16' lund, and a little heavier, will this trailer haul the sylvan, the title on the trialer says 1,000 lbs. i have a pic of the boat on the trailer, the trailer needs adjusting, but if it wont pull it i need another trailer<br /> :confused:
JB
Re: 1975 shorelander
Howdy, ckremer.<br /><br />I take it your Sylvan is an aluminum semi-vee, and I think a 1,000# trailer will handle it if it is not packed with too much heavy gear.<br /><br />Good luck. :)
ckremer
if you want i can email you a picture, looks like it has some adjustments , my email is ckremer7@msn.com that way you can see the way the boats sits on the trailer, i havnt adjusted anything yet, but if the trailer can handle the load i will keep it
rwidman
You can take the rig to a public scale, truck stop, or recycling center and get it weighed. The trailer should have a capacity label on it somewhere, if not, contact the manufacturer.
