Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Changing bulb on trailer lights
  • Changing bulb on trailer lights
    I pulled the cover off so I could change the light bulb and there's a clear plastic cover over the light bulb. It looks kinda like a bubble over the bulb. How do I take this apart? Thanks guys
    Re: Changing bulb on trailer lights
    I've seen a lot of trailers in my time...but I don't think that I have ever seen what you just described!
    If nobody jumps in with an answer, maybe you could snap a picture?
    Happy boating!
    • #3
      They don't come apart. You have to replace the whole bulb.
      "A manual is a cheap investment"
      Fair Winds and Following Seas
      Bill
      PTC USN ret
      • #4
        That's basically a waterproof capsule protecting the bulb. You change the complete unit inside the lens housing. Mine has these lights, made by Wesbar.
        They make one for the right side and one for the left side.
        http://shop.easternmarine.com/index....productID=5058
        • #5
          He is correct. They are made to be water tight so when the bulb burns out you do have to replace the whole thing. I just changed a friends and was suggesting he go to LEDs. He told me that he had the boat and trailer for 7 years and this is the first time he has had to replace the fixture. So he didn't think that replacing them with LEDs were what he wanted to do. I would have opted to replace them with LEDs for the simple fact that they are brighter and are water proof. I guess it is up to you. I just like people to see my trailer at night.
          sigpic "Spend a little money, save a lot of time"
          • #6
            Thanks guys
            • #7
              Interesting approach to submersible lighting! Like I said, I have never come across one of these.... I can see where an owner of these lenses would opt to replace the bulb(s).
              Apparently, the 'right vs. left' only applies to the lens units...the bulb for either is the same number?
              Nice detective work!
              • #8
                http://www.wesbar.com/product/detail...03308&cat=8960
                1 screw holds it in and the new one has to be wired.
                Bill
                PTC USN ret
                • #9
                  Wow, ya'll a lot faster than me in looking them up. I got tired of fooling with them and went to LED.
                  Bill
                  PTC USN ret
                  • #10
                    I just posted about this light assy. them I googled it and found the post.
                    is there a number for this assy ....I need one
                    • #11
                      Waterproof Low Profile Tail Light Replacement Capsule - Wesbar 403348 - iboats
                      Order 2 so you have a spare.
                      Medford, WI
                      • #12
                        NONSENSE! You don't need to spend the big money to replace the capsule--if you are willing to do a little work. Use a very fine hacksaw blade and cut around the bottom of the clear capsule. replace the bulb and use a good plastic cement to reseal the capsule to the base.
                        Since I am tighter than a crab's a**, and that's water tight, I have done it once or twice on my Caulkins trailer. I just can't justify spending 11 bucks on a 1 dollar bulb. In fact, I am so tight that I re-use bulbs salvaged from junkyard autos and save that dollar too.
                        • #13
                          Assault Squadron NINE
                          River Assault Division NINETY-ONE-1966
                          • #14
                            Ahhh, fellas, this thread is almost 4 years old and needs to back where it came from, the archives....
