Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
need help to get boat on the trailer
  • need help to get boat on the trailer
    ok, i have been struggling with this for over a year and think i have tried all solutions, but i know that someone else out there has the answer, i have no problem launching my boat at the ramp on my own, but to get it back on is pure hell, i have tried to install guide ons, no luck, tried different depths when i back the trailer up, no luck, my problem always seems to be that once the boat gets on the bunsk, it falls off one side or the other, i have a 14ft aluminum boat and a staright tounge trailer, 2 bunks on the end and a keel rooler, towards the fron, should i try installing more keel roolers further back by the bunks so they grab the boat quicker?any help would be appreciated,usually after messing with the boat for 20 minutes to get it on, i end up just walikng into the water and positioning the boat that way.
    Re: need help to get boat on the trailer
    I fought with my 22fter for a few months until I fitted 'Retriever-mate'. The roller are spring loaded and easily centre the rear of the boat as you pull it up. They don't suit all trailers. web page Its an Aussie link but I'm sure they or a similar product is available in the U.S.Aldo
    Watch this space......................
    • #3
      craneman... is this a factory trailer designed with your particular boat in mind? are the bunks the proper width and angle for your boat hull?... just a thought. on occasion loading can be a problem, but consistent trouble sounds like something is wrong with the way the bunks might be set up.. hope this helps a bit. good luck....bob
      • #4
        Sounds like the bunks are to short or to low, how long are the bunks? and where to they contact the hull in relation to the keel or strakes?, also does the winch strap appear to be inline with bow eye, or is it at an angle to the bow eye?, let us know and hopefully we can provide some feedback.
        • #5
          not a factory trailer. but the bunks are about 3 foot long, they lie directly beside the rail on the bottom of my semi v, the back of the boat is totally flat and the bunks fit in between the rakes? i believe that is what they are called,the bow eye is perfectly straight in line with the winch strap when on the trailer, do you think that perhaps the trailer is too short/too long, the boat is a 14ft aluminum gamefisher, semi v, the transom sits at the very end of the trailer and the bow rests about 4 foot behind the coupler, i never have a problem turning with the trailer on the truck?
          • #6
            I read this from a magazine and it work well for me. The answer is don't dip the trailer too deep. Back the trailer down deep enough like when you launch the boat then pull it up a bit. This would allow better contact between your hull and the bunk. You will need to use your engine to push the boat all the way up. But once you do this the boat will not slide side by side.
            • #7
              not sure, but u might simply be going too deep with the trailer when u load. try leaving 2/3s of the bunks out of the water when u load. it might be a little harder to winch on but u will have more contact with the bunks. it sounds like the boat is floating when u come out of the water, instead of sitting on the trailer. just a thought....bob
              • #8
                I agree with rc581, but if you are able to support longer bunks say 6-7 feet then the boat will make contact sooner and be more stable, I load a 20ft boat on 12 foot bunks, works good, the old trailer I had for same boat only had 8 foot bunks never did load as nice as the one I have now.
                • #9
                  With the boat on the trailer, the bunks should extend to the transom or slightly past (1"-2").If the do not, replace/adjust them so that they do.If they extend that far back, loading should be much easier. As long as the bow is between those two bunks, it cannot come up crooked, as long as the trailer is not too deep.
                  • #10
                    If your trailer is set up correctly, rc581 is correct. I trailer an 8,000 lb 26 ft mid cabin cruiser on the coast with wind and currents. The best way to avoid the trouble you are having is not to back your trailer down as far in th e water and power the boat up on the trailer or winch it up. I learned this from a guy with 38 ft center console who trailers his boat on the coast.
                    • #11
                      bunks do extend all the way to the end of the transom, it seems that my biggest problem is once i back the trailer in, and then attach the guide rope to the bow eye and push the boat out and try to pull it on the trailer, the boat always goes off the trailer, thats why i installed the guide ons, but even with those, i have a hell of a time, i can pull the boat on about half way, but then no more so i end up walking into the water to attach the winch strap, to winch the rest of the way on. maybe i am missing a step somewhere???
                      • #12
                        hello again craneman. if your trailer is set in the water properly, u should be able to run that boat on to within 2 feet of your nose dock, and then put the winch strap on to winch the last couple of feet. u should NOT have to go in the water to do this, but be able to lean out standing on your trailer tongue to snap yor winch strap on. if u cant, then yes there is a step missing here, but we are all missing it... do u have alot of gear stored on the boat all on one side or something of that nature thats causing the boat to lean?? sorry craneman, but im running out of ideas for u to try. wish i could be of more help.let me know how u make out.....bob
                        • #13
                          There are or may be a lot of issues here but if you can once get your boat on the trailer the way you want it. And it rides the way you want it to on the trailer here is what I did. Bunk or Roller it will work the same. Float it on, power it on, or winch it on, it doesn't matter. The boat has no choice but to sit in the same place everytime.I call them side guides..Some call them side bunks..Anyway they are carpeted 2X4's or 2X6's and you set them after your boat is centered on the trailer with just 1/8 a inch from your hull on each side of the boat. Your boat will always center its self. A added plus is that in rivers or in or out going tides all you have to do is hook the bow in and power in until the boat is straight and held by the trailer. Then winch it in if thats what you do.I just bought the 2 foot one then bought longer 2X4's and used Marine carpet to set mine up.14 years later and it still works every time.BTW if your trailer goes to deep or is too shallow NO Problem. the boat doesn't have a chioce.. with only a 1/8 inch on each side the most it could be off is 1/4 inch! This isn't the brand I use but since this is sponsered by IBOATS I use their adds http://www.iboats.com/mall/index.cgi...t_id=258728054 Hope this helpsLink
                          • #14
                            If you leave about 1/4 to 1/2 the bunks just about at water level or a hair above, just power on the best you can between your guide ons. Even if the front of the boat goes off to the side dont worry about it. Once you come to a stop step over the bow onto the tounge, with a boat as light as yours you can simply pull the bow to align with the keel roller, then it's just a matter of hooking the strap and winching it up to the tower roller. I use a pickup and once I have it winched up I step into the bed and climb over the side, never get my feet wet. I do this with my 14 foot aluminum. Step plates on the tounge make this method even easier. Are your guide ons set close enough to the boat? I have mine about three inches from each side.
                            • #15
                              i think i may have found my missing step, by reading everyones responses, it sounds like after backing the trailer in the water, everyone is getting back in the boat and trying to drive on the trailer, then setting the winch strap, what i am doing is after backing the trailer in, i use a line tied to the bow line and push the boat out and try to guide it on the trailer that way, should i try to get back in the boat and then drive it on the trailer, i do not have a drive on trailer, but if i do it slow enough i dont think there would be any problems, the only problem i can see with all this is that i have a bow mount trolling motor so it would be kind of hard to step over the bow on to the tounge of the trailer.what do you guys think?????
                              Back to Top
