Re: Shorelander trailers
I'd never own one, period.<br /><br />Dad bought a new one 6 years ago and it has broke 6 times. It came with his new Alumacraft.<br /><br />Weld where tongue and frame meet, cracked on first trip, with less than 1000 miles on trailer.<br /><br />It is an all roller trailer, with pivoting crossmenber across the back. Pivot bolts have broke twice, dropping the boat onto the trailer frame and punching holes in the boat. The last time, it dropped down far enough to smash the lower unit of the motor ($1100).<br /><br />Roller bracket assembly broke and dropped off.<br /><br />Front keel roller and bowstop roller wore thru 3 or 4 times. Cracked in half on the first trip.<br /><br />No it was not overloaded.<br /><br />This fall, dad helped another stranded boater with the same trailer. The pivot bolts on the back of his trailer both broke. The crossmember, brackets, and complete roller assemblies went flying off. The entire bottom of the boat was tore up. Several holes big enough to put your arm thru. <br />Try starting your vacation by building a log frame on top of your trailer, then securing your boat to it, so you can haul it back home and throw it away.<br /><br />Oh yeah, they are real nice.
