Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
Registering a trailer without serial numbers
  • Registering a trailer without serial numbers
    I boat a boat and a trailer. They have not been on the road or the water since 97 and, I need to register the trailer with a PA title. The previous title was lost. Also there are no serial numbers on the trailer. How do I go about registering it?
    Re: Registering a trailer without serial numbers
    You mean without perjuring yourself?
    Have the previous owner apply for a replacement title.
    If there's anything else that's legal I don't know it.
    Why does a round pizza come in a square box?
    • #3
      i did this with my old treailer sey that its home made. all i had 2 do was go 2 the dmv with the treailer get them 2 check it out and u get a pink slip. pretty easy and if u do have a license plat throw it away bechase they will charge every year it wasnt rejisterd comes out 2 a lot of money if u dont...
      • #4
        Was this recently?
        Or is it really that easy in Cali?
        • #5
          In Florida, if you can show the last registration, or even have the last tag # that was on there, they should be able to verify what the vin # is. Then you can make your own ID plate with said vin # punched on it, and mount it.
          • #6
            Originally posted by HappierWet View Post
            Was this recently?
            In NC this is also fairly common (although alot of times it depends on the Highyway patrol man that has to (legally) "inspect" the trailer), alot of times this just means watching you stamp the vin # they assign you on the tounge.
            I have taken (an obviously factory built trailer) that I had to replace the tounge on and called it homebuilt (it passed and they gave me a title).
            Also (while not the legal way to do it), if the trailer has NO #'s on it, if you own another trailer you could use it's regestration/tag when you tow the boat... Again, this is NOT a legal way to do it.
            90 Four Winns Horizon 220
            96 Seadoo Spi
            88 Kawasaki JS650 (Stand up w/built engine)
            • #7
              Register as homebuilt... they will give you a VIN for it...
              • #8
                In Ohio all they need is a weight slip. I have a friend that used his old trailer's slip (after he sold the trailer) to get tags for his new trailer cuz he didn't want to go through the hassle of unloading boat (& keeping it safe), driving to scale & picking boat back up. This guy been using it for years, the state just wants their money.
                My 16' '75 MFG Restore
                http://forums.iboats.com/showthread.php?t=448087
                • #9
                  yep it is.. cost me 45 dollars 4 the pink slip and tags and 40 for the plates
                  • #10
                    In Illinois, I simply took off any decals of the name brand and then registered it as homebuilt. They then assigned a VIN number that you stick onto the trailer. If it is under 3000 lb load capacity, they don't even check it. Over 3000 pounds you have to get it inspected.
                    • #11
                      Trailers without titles or home made trailers are a PITA in PA.
                      You can either treat it as homemade; http://www.dmv.org/pa-pennsylvania/o...f-vehicles.php, or go over to NJ and register is there. NJ will assign it a VIN # and issue a title as homemade without a ton of BS. When I lived in PA I did it all the time. If they ask, just say you plan to fish or boat in NJ. Either way it gets you a legal tag.
                      • #12
                        [QUOTE=reelfishin;2379148]Trailers without titles or home made trailers are a PITA in PA.QUOTE]
                        AMEN Brother
                        • #13
                          if u try to register it in pa as a homemade make u may have to take it to a special inspection station, take pictures etc. like they said a real pita in pa.
                          all axels need breaks if (i think) over 3000lbs.
                          john
                          • #14
                            I live in Pa , and yes , its a PITA. I posted an ad on Craigs list for broken down trailer with Pa title....offered $25.00 and removal. Got a reply about a broken down trailer , offered the guy $25.00 and cut his rusty old trailer up in 1/2 an hour and he handed me the signed title... good enough for me....
                            Good judgment comes from experience...experience comes from bad judgment........ask me how I know.
                            sigpic1990 Bayliner 2002 Capri Cuddy /125 Force " Breaking Wind "
                            • #15
                              Thanks for the advice. I figured I would have to register as homemade. It is for over 3,000 and does have breaks on the axles.
