Re: Hard to Find Tire Size - Substitute?
At 1360 per tire or 2720 per axle, you are close. Plus most manufacturers make their tires higher than the minimum rating, so you will see differences of about 20 lbs or so between the same size between models and manufacturers.
Either way, if you can afford to upgrade to a 14" and have the fender clearance, think about that.
