Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
changing 8" wheels to something larger on a 4 lug rim.
  • changing 8" wheels to something larger on a 4 lug rim.
    is there a larger rim that will fit my 4 lug trailer wheel? i believe they are 4" bolt circle diameter.
    As in people, there comes a time in your life when you realize what boat will always matter, what boat does matter, & what boat never did. So don't worry about the boats from your past, there's a reason why they didn't make it to your future. .
    1978 MFG Gypsy Rebuild Thread
    1978 MFG Gypsy Rebuild Video
    First Launch After Rebuild
    1979 Sunray SW149 Bow Rider Rebuild Video
    1976 Sunray Boat Floating At The Wharf
    Re: changing 8" wheels to something larger on a 4 lug rim.
    4 lug 12", anything bigger than that is gonna have 5 lugs
    1967 WestWind "Aerodyne" 14' Runabout
    sigpic
    Just Keep N it Reel!!!
    My restoration in progress
    • #3
      besides a standard trailer wheel, is there maybe a car wheel that would fit?
      • #4
        Unfortunately, car wheels are offset from the hub, some more than others. Trailer wheels are centered, if you can clear the offset under the fenders then look at old fords.
        • #5
          I've owned two Sea Lion Trailers with 13" 4 lug rims, as well as a current Escort trailer that original came from a Bayliner 16' boat.
          12" is more common though.
          The lug pattern for most 4 lug trailers is 4 on 4". A 4" bolt circle is closest to a 100mm pattern on some Ford Escorts but those rims have the wrong offset.
          Try this site for comparisons.
          http://www.vehicle-bolt-pattern.com/
          • #6
            Close, but still won't fit even if you ignore the offset. The 4 on 100 mm bolt circle is very common on small cars, but I've only ever seen the 4 on 4 inch (102 mm) bolt pattern on trailers. 12 inch, 4 bolt trailer wheels should be fairly easy to find though.
            • #7
              Tall,
              check this out......www.kmtparts.com
              if iboats don't have what you need
              woosterken
              woosterken
              '74 MFG gypsy
              '95 F150 4X4
              • #8
                Just replaced my 570-8 tires/rims with 530-12 tires and rims. Both 4 bolt rims.
                Needed the extra load capacity and had clearance under the fenders so the switch was easy. The 12" tire is 2" larger in diameter so I now have 1" more ground clearance but thats no big deal to me.
                Whats the reason for larger tire?
                • #9
                  Originally posted by woosterken View Post
                  Tall,
                  woosterken
                  awesome site. thanks a bunch. imagine a 15" wheel on a 4 bolt pattern. cool.
                  • #10
                    no real reason. i think a larger wheel/tire would tow better and be easier on the bearings. it will raise the trailer up a bit.
                    • #11
                      Tall,
                      woosterken
                      Great lead on the tires, the prices are the cheapest i've seen so far, about $20 less per tire & rim set.
                      sigpic
                      • #12
                        I know that the Chevette rims will fit most trailers and in order to compensate for the offset turn the rim around. Your steam will be on the inside. The dimensions for the stock Chevette wheel are. Measuring from the outer rim to the base of the lug nut hole: 1" (Outside rim ) and Measuring from the outer rim to the inner mounting surface: 4" ( Inside rim )
                        My uncle has them on his boat trailer, and uses a standard 8" for a spare.
                        • #13
                          New 12 inch wheels are cheap (relatively) so don't take a chance on an auto wheel that very likely has the wrong offset, wrong, taper on the lug bolt hols, and wrong bolt hold spacing. Check your local farm stores as they often have a good selection of trailer parts. By farm stores I mean Fleet Farm, Farm & Fleet, etc.
