Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Tri hull trailer
  • Tri hull trailer
    How would I go about finding a better trailer for my tri hull? I despise the trailer that I currently have. How would I know what type of trailer I need? Its very hard to launch and retrieve with the trailer I currently have. If I cant find a new one how do I determine what height to set the rollers at?
    Re: Tri hull trailer
    How about some photos of your current setup? It's really hard to discuss the problem without seeing it.
    I had a trihull, and it was on a pretty standard roller and bunk trailer. It worked very nicely. What I do, and this is just my perspective, is adjust the bunks to just level it on the trailer, and rely on the rollers for most of the weight-bearing. Of course, that means plenty of keel rollers to spread out the load.
    I do the same on my current semi-V aluminum boat. It sits on the rollers, with the bunks basically just contacting to keep it level from side to side. It loads and unloads easily, and I'm using 4 keel rollers on a lightweight 12' aluminum boat.
    So, describe what it is you don't like about your current setup. Illustrate with photos, if possible. Describe how your trailer is set-up. How many rollers? How long are the bunks? How much of the weight is on the rollers and on the bunks?
    Trihulls are really no harder to set up on a trailer than any other type of boat.
    Sure...go ahead and laugh at my old aluminum boat. It's paid for!
    • #3
      OK, I found a photo of your setup:
      I'm assuming that you have bunks contacting the space between the outer hulls. That's pretty typical for trailering this type of boat.
      I see one keel roller at the front. I assume there is one at the rear of the trailer, as well. Are there any other rollers? You may have too much of your boat's weight on the bunks, and that can make loading and unloading difficult. More center keel rollers can help.
      Now, what is it about this setup that you don't like. Are you having trouble launching? Or is the problem on the retrieve?
      I see no reason why your trailer can't be setup to make your job easy.
      • #4
        my first impression is the trailer is too small for the boat, needs longer tongue to get the boat in the water, longer bunks to support the stern. additional keel roller/s. using the tilt mechanism may help of shallow ramps.
        FLORIDA GATORS
        TEBOW Country
        Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
        That is what these forums are for. Post your questions, in the appropriate Forum.
        • #5
          He has the same problem I did on my trihull. The boat sits pretty high on the trailer, and there's not much that you can do to lower it. What worked for me was to have four rollers for the keel and most of the boat's weight on the rollers, with the bunks more for stability than weight-bearing. It didn't cause any deflection at all on the keel. I'd have put six rollers in if I had enough cross-members.
          As long as I could get the stern in the water a bit, I could fairly easily shove the boat off the trailer. Retrieval meant positioning the rear roller even with the water, then winching the thing back on the trailer with the grooved rollers easing things along. The bunks didn't really come into play until the boat was almost loaded, and then they made full contact once the bow was in the bow stop. The keels on those trihulls are the strongest element on the boat, and handle the weight just fine on four rollers. The bunks can just stabilize the boat horizontally, but do need to be in full contact over their entire length.
          His is about a foot longer than mine was, but mine sat on the trailer about the same as his. I never had any trouble launching or retrieving, and never used the tilt feature. I did avoid really shallow ramps, though.
          • #6
            One other thing. If you're worried about too much weight on the keel (I wouldn't worry), you can use roller bunks to allow the bunks to carry more of the weight. That'd make the boat super easy to launch and retrieve. Just don't release the winch until the boat's in the water, ready to launch, or it'll end up on the ramp.
            • #7
              "it'll end up on the ramp." i know from experience, friend helping me launch disconnected mine, i saw the boat move before it was bad.
              FLORIDA GATORS
              TEBOW Country
              • #8
                PK,
                check your PM box put some info there for you
                woosterken
                woosterken
                '74 MFG gypsy
                '95 F150 4X4
                • #9
                  It happened to my father, too, once. It was a steeper ramp that the one he usually launched from, and he was used to backing down and hitting the brakes to slide the boat off into the water. Well, his 23' boat started moving down as he was backing. So, he punched the accelerator a bit and got the trailer in the water just as the boat slid off. No damage. Since then, he's been a bit more careful.
                  • #10
                    It looks like the front keel rollers are more for centering the boat up front. They form a "V" to hold the keel from deflecting side to side as the boat comes up on the trailer. I'm willing to bet that the rest of the rollers are pretty old also. I've seen those trailers, and was never impressed with them much.
                    I'd say that if he's dealing with bunks that are hard to get the boat moving, then he might want to invest in the plastic slides that you screw into the bunks to help it get a little more slippery on a dry launch/retrieve.
                    my thread here,My Shareproject page,Part 1,Part 2,Part 3,Part 4
                    Official Tri Hull Club thread
                    • #11
                      would you just have to get the trailer farther in the water then? and once its off the trailer and floating then disconnect the winch?
                      the only boat ive ever seen/ launched wasnt a tri-hull or a roller.
                      mine is a tri hull and rollers.
                      CrankyBaits Custom Painted Lures
                      1981 Sylvan Sportster 16' 1985 Evinrude 70 hp
                      • #12
                        Some folks have the habit of unhooking the winch cable at the top of the ramp before backing down. This works OK with some boats and trailers, especially those with bunks only. You back down and when the boat floats, you stop and the momentum lets the boat back off the trailer by itself. Guys launching solo often tie the bow rope to the truck, then untie it and walk the boat to the courtesy dock.
                        Roller trailers don't work so well when you do this. They tend to roll off the trailer before you get to the water. It's a bad idea.
                        Combination roller and bunk trailers are in the middle of things. You really have to know your combination, and a steeper than usual ramp can throw things off and put your boat on the concrete.
                        • #13
                          thank for the advice!
                          • #14
                            I've launched a few larger boats on full roller trailer which were a real job to get unhooked once on the ramp. The boat's weight would remain against the winch and there was no way to get far enough back into the water to let the boat float free with that type trailer I used to disconnect the winch and wrap the lead rope well around the bow stop so I could easily release it once in the water. While I never had to launch that one alone, I would toss the lead rope to a buddy on the dock to pull the boat over to the dock while I parked the truck and trailer. I'd then just run and hop in the boat, warm it up and be on my way.
                            I've had a few roller trailers on which the boat still didn't move very freely, but after switching to new Yates rollers, it's slides right off.
                            I've had several trihull boats, all were on bunk or roller bunk trailers. Keeping them low is pretty important when it comes to launching.
                            There are several type trihull designs too, some are no more than a deep V hull with two outer hull formations and others are true tri or 'W' hulls ending in a true three hull shape, while others are more just flat bottom hulls with a tri hull bow area. On the true 'W' hull boats, its usually easiest to set up the bunks to set in between the two outer hulls and the main V hull. Roller bunks work well on the flat bottom and mild V bottom hulls, and many can be put right on a standard full roller trailer.
                            My Starcraft Capri and Duo Gypsy both worked well on standard trailers.
                            The good thing is that most of those hulls were rock solid and fairly light. My Starcraft was only about 800lbs plus the motor. The floating boat was only about 1500 lbs with fuel, a 120hp Evinrude V4, seats, fishing tackle, coolers, and my home built casting deck. The trailer was a 12' tire TeeNee that came with another boat. I never felt it was under sprung or overweight at all. I later put that boat on a Load Right 19-2500 trailer which worked fine, a bit heavy but it made it nicer to travel farther.
                            • #15
                              Hello,
                              It has mini bunks on it just to keep it from swaying. I have to back this thing so far into the water to launch it since it sits so freakin high. I can try to lower the bunks and see if it helps. also I will try to raise the rollers a bit. I have had three other boats and they were very easy to launch. The trailers also sat lower and were longer. The boat seems to big for the trailer to me.
