need help on replacing crossbars-odd size-shoreline trailer
jforsyth
Hey Folks,
Some of you helped me out recently so I thought I'd try again. I've got an old Shoreline trailer. The rear two pivot bars were rusted and someone on this forum gave me a link to a website which has a suitable replacement. Thanks!
The next problem is that I realized that the rear crossbar is also badly rusted through. :eek: I've searched & searched various trailer parts websites and it seems as if mine is an odd length. It is 3" square, V shaped w/ a 4" drop at the center point. The length on a straight line is 53 1/2" from inside of main frame to inside of other main frame. My crossbar has a welded tab (on the top) which bolts through the main frame to the other side.
Any advice on how to get a suitable replacement crossbar which will fit this trailer? Are there any supply shops which can custom make one to fit? Any help?
Thanks
The_Kid
Re: need help on replacing crossbars-odd size-shoreline trailer
Most welding shops should be able to make a replacement. Take the old one and they should be able to duplicate it.
