Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
How too attach a safety chain to a boat trailer
  • How too attach a safety chain to a boat trailer
    My boat trailer does not have safety chains on it so I need to add them. My question is how do I attach them to the trailer? Do I drill a hole and run a screw.
    H e l p
    Re: How too attach a safety chain to a boat trailer
    take out the forward most bolt on the coupler and replace it with a longer bolt. when you put the bolt through the chain put a washer on each side of the chain. make sure to use a grade 5 or higher nut and bolt.
    1998 Four Winns 245 sundowner, Volvo 5.7GSI/Duo prop
    • #3
      If the coupler is welded on you will need to drill a hole. And use a bolt, washers, lockwasher and nut, not a screw (there is a difference).
      • #4
        As Silvertip !!!!
        sigpicMarada 2100 Executive Series, 5 Litre V8 with Mercruiser Alpha 1 outdrive. 2007 K-Z Spree 260 RBH, all = a whole lot of family fun !!!!
        • #5
          yep as silvertip
          [SIGPIC] 1982 Baja 16ss
          • #6
            The guys are right about the mounting and grade, and I add that you use large enough chain and clips or shackels (not S hooks, they are a joke ). S hooks can bounce off or bend open in the case off the unthinkable happening, and I wouldn't trust my boat to them. Improper safty chains cost my brother his life when hit head on by a towed vehicle that got away from the owner. Thats something that would be hard to live with, losing a life over a few bucks. Whatever you do, think safety first ( SAFETY CHAINS )...
            Happy Towing...
            " It aint no fun, If the boat don't run... "
            • #7
              Would you guys mind posting a few pictures of what a good safety chain setup looks like, or point out a link with good information. I am a new boat owner and want to be sure what I was shown is the right way and not just a way to get a false sense of confidence in such an important thing.
              "Play Together, Stay together!"
              Stingray 220DS, Mercruiser 5.7, Alpha 1
              • #8
                I had a 20' Beachcraft on a Zieman trailer with 1/4" thick cable. The trailer broke lose one day and fortunately I was going very slow. That cable just snapped in two. I replaced that cable with 3/8" chain and have since sold the boat and trailer. On my current 21' Trophy I've attached a 7/16" chain.
                • #9
                  On my trailer, just behind the coupler, there is a piece of L-steel welded on each side, (like the letter V attached to the bottom of the tongue) and the chain goes through it. Then, a grade 8 bolt secures the chain from sliding, keeping the chains at equal length.
                  While you have your tools out, help prevent ever having to use the safety chains and make sure your coupler is adjusted properly since your working in that area.
                  Overkill.... probably. Will that trailer ever get away from me? Not a chance.
                  This coming from a guy that had a trailer come loose @ 65MPH once. Never again!
                  • #10
                    Just an aside.
                    You need a chain on either side of the coupler, and cross them under the coupler. It the coupler ever does pop off, it will fall down and get caught in the chains. It won't drop as far as the road.
                    1977 Starcraft 18' SS 1980 Evin 115
                    • #11
                      Hmmm, I have always crossed my chains, however, If the trailer falls I can see how the coupler will hit the road.... Is there any formula to determine the length of the chain? I believe this question goes with the OP line of questioning. If not please let me know and I will start a separate post.
                      1975 Cobia Tradewinds SS-170
                      Close Bow 17 Footer V-Hull
                      1975 Evinrude 70573-B 70HP
                      1968 Babcock
                      Bow Rider 15 Footer Thrihull
                      1968 Mercury 500 50 HP
                      Yes, I could google it, but I rather get advise from my Iboats fellow members...
                      • #12
                        if your handy, and a good welder, or know of a good welder, i think welding would be the way to go. lock nuts tend to wear out from the elements and have the possibility to become loose. so taking a 7/16 chain and welding it to each side or something to that affect might be a better way to go.
                        i didnt see where post had been given with pics so maybe this will help...
                        http://www.ultra150s.com/PWC_Trailer...upler-lock.jpg bolt, washer and lock nut
                        http://www.bulletprooftrailers.com/i...afetychain.jpg chain welded to trailer.
                        hope this helps
                        Mark
                        • #13
                          Most recomend against welding the links as it weakens it...
                          1968 Babcock
                          • #14
                            I agree with Nandy about welding- I would bolt it.
                            If the lock nuts rust- just replace them.
                            I added a safety chain to mine, and drilled and used a pass through bolt with a chain holding spring locked hooks hanging from either side of my welded on coupler.
                            1967 Sears 14' V-hull with full redneck bass boat conversion! Fitted with a repainted 1975 Johnson 15HP, and Evinrude bow mounted foot controlled trolling motor...
                            • #15
                              I weld mine on, only because I enjoy welding stuff. As for welding making it weaker...I disagree. I've only had the coupler come off of the ball once and it was hard enough to snap one of my chains. It snapped in the middle of the chain. If welding made it weaker it would have snapped where it was welded to the trailer tongue. Only my observation and opinion.
                              All that being said, drilling a hole and using the right nut/bolt hardware works excellent too! A no brainer if you can't weld or don't have access to a welder.
                              Hunter
                              Back to Top
