Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Moving a boat aroud the garage?
  • Moving a boat aroud the garage?
    Hi friends
    Well I just got back from a 1000 mile round trip to get my boat, whew.
    I knew it was going to be a tight fit in the garage and I was right, it took some negotiating but it is inside now, safe and sound.
    My question is, is there a device for moving a boat & trailer around the garage without a vehicle? Maybe like a special hand truck sort of device, either manual or with a small motor.
    Geo
    Re: Moving a boat aroud the garage?
    Yes, I have a little two wheel dolly that has a tow ball mounted on the top. Works great. I got it at Harbor Freight.
    I use to use a furniture dolly under the jack before I bought that and just push the trailer around.
    On my trailers though I usually retrofit with a pivoting, swivel wheel.
    All work.
    1987 Boston Whaler "Outrageous 18"
    1989 Johnson 120 V4 VRO
    • #3
      I just use an old garden tractor, I moved the axle back on a trash picked tractor from Dynamark about 15 years ago and it's been a life saver ever since. You would be amazed at what one of those things will haul! I've moved my triaxle equipment trailer around the yard and moved several fairly large campers all over with it. I've even taken a 24' enclosed trailer down the road to a neighbors yard with it with very little trouble. (Just don't count on the brakes doing much when pulling a stunt like that).
      • #4
        Welcome to iboats!
        Here is a link to Harbor Freights trailer dollys.
        http://search.harborfreight.com/cpis...=trailer+dolly
        sigpic
        1989 Maxum 2000SR
        Merc 305/230HP
        • #5
          Originally posted by cbear34 View Post
          Welcome to iboats!
          Yep, thats the one. Moves boat trailers easily if you keep tire inflated. Although, a tractor would be real nice.
          • #6
            use the lawn tractor if the boat is on the grass. but i have these for the concrete. also saves my back.
            http://www.iboats.com/Marine_Store/d...-submit%2Ey.10
            FLORIDA GATORS
            TEBOW Country
            Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
            That is what these forums are for. Post your questions, in the appropriate Forum.
            • #7
              That is what I have on my trailers. Swing up wheeled jacks.
              • #8
                I tried one of the dollys and have decided to get a good used lawn tractor and put a hitch on the front.
                The question is "what horse power is needed to push around my rig?"
                I am thinking trailer, boat, and motor should be around 2000 lbs.
                Would this garden tractor get the job done?
                http://raleigh.craigslist.org/grd/623299344.html
                Thanks everyone!
                Geo
                • #9
                  mine is a 12 hp.
                  FLORIDA GATORS
                  TEBOW Country
                  • #10
                    Welcome to iboats!
                    Cbear: Do you think that heavy Duty trailer Dolly would handle a 4,000 Lbs boat and trailer? I too have the swing down tongue wheel jack and it's a bear for one person to move my boat by hand even on cement. On grass forget it. I see it says 600 LBs tongue weight. I'll bet my tongue weight is closer to 900 Lbs. I weighed at the scales at 3,980 Lbs.
                    Chuck
                    "OWN-IT II"
                    1986 Four Winns Horizon 190
                    1982 Aqua Patio
                    50 Hp Two stroke
                    • #11
                      I see that you were asking cbear but let me tell you from recent experience that it is does not really roll any easier with the dolly, the biggest advantage I found from the dolly is that you actually have a handle to push or pull but it does not change the fact that you are moving such a heavy weight.
                      I bought one and will be returning it this week, I just can't afford to mess up my back.
                      Geo
                      • #12
                        Thanks Geo. That's what I thought so that's why I haven't ever bought one. I've had two back surgeries so am I'm pretty cautious about what I do or how I do it. It's safe to pull but I must be very careful what I push.
                        Chuck
                        "OWN-IT II"
                        1982 Aqua Patio
                        50 Hp Two stroke
                        • #13
                          The tongue weight should only be around 300 to 600 max.
                          • #14
                            Thanks everyone!
                            Geo
                            That should be big enough if it is hydrostatic drive and the hitch is on the back. If it is on the front the front tires are small, will sink into the ground easier and might get overloaded. And the rear axle will be "unloaded" and not get the traction needed to move anything on the front hitch.
                            Mine is a 38 year old 12hp Cub Cadet and I move a 4000lb rig around the yard. I would reccommend adding a 2" receiver tube hitch and use a drawbar that places the ball at the same height as your regular tow vehicle.
                            Most lawn tractor hitches are so low the trailer can't get that low.
                            • #15
                              cbavier
                              I am not actually sure. I have seen these in the Harbor Freight catalog. I have a wheeled swing up jack and can easily roll my boat around the garage. My garage floor is smooth and coated and my boat only weighs around 2000 lbs.
                              sigpic
                              1989 Maxum 2000SR
                              Merc 305/230HP
