floater212
- Nov 27, 2013
- 145
what type and brand of trailer grease do you use? my concern is I end up blowing out my seals, i've seen where it said you need a light weight high temp grease for boat trailer bearings with disc brakes ( they run hotter than drum), but also somewhat need water resistant. if it's low temp then it's getting too hot and seeping out, but higher temp is usually thicker so it will push past seals. by the way i have easy-lube axle which has the zerk on end of axle and it comes out between inner seal and bearing. i don't drive too far during season, 5-6 times at 40 miles each way and 1 long trip say 150 miles each way. what's your preference?
