Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Help with trailer wheel size
  • Help with trailer wheel size
    Hi all, I have a 18ft, 1990 Ranger 361V Comanche with original trailer. I just had a blow out on one of my trailer tires. I changed the tire, came home to research what tire to buy. This is my 1st time. I quickly found out that I have automobile tires on and not trailer tires. Could someone tell me what load range and what size tire to buy. Thanks in advance
    What size rims do you have?
    1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
    Past Boats
    1970 Wooster Hellion - Merc 9.8
    2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
    1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
    What’s behind you doesn’t matter.Enzo Ferrari
    • #3
      Tire size on it now is P205/75 R14
      • #4
        The trailer should have a sticker on it with information about recommended tires & load ratings from the factory. However, if it does not Iíd probably look for a similarly sized radial trailer tire in a load range C or D for that size boat. D is probably slightly overkill, but I like the added peace of mind. Note that a D rated tire will have thicker sidewalls & thus ride a bit stiffer than a C (also pros/cons to that).
        Definitely spend the few extra for a radial vs. bias ply as they tend to hold up better in my experience & run smoother. Look for an R in the size instead of a D (eg, 205/75R14ST vs. 205/75D14ST).
        Benjamin Krein
        Floats: 2008 Four Winns H200
        Restoration: 1980 19' Century 190 Restoration
        Tows: 2005 Nissan Titan SE
        • #5
          Thanks for all that great information. I am at work now, but when I get home I will check for that sticker. And I will take your advice and get the radials. You guys rock!!!!!!
          • #6
            Chance are extremely high that your tire blew due to old age or actually more likely, low inflation. Inflation critical on trailer tires!
            • #7
              Thanks ahicks, I will definitely be more cautious of trailer tires for now on. Luckily I wasn't on a highway and could pull over quickly.
              • #8
                Also note that trailer tires have a lifespan/shelf life. They dry out & wear out internally sometimes before they appear worn out externally. The treads may look fine but the sidewalls might be dry rotted or there may be internal belt separation etc. itís typically expected that trailer tires should be replaced every 3-5 years as preventative maintenance. Iím sure many have gone much longer than that, but it becomes a gamble.
                Benjamin Krein
                • #9
                  Just so you know, that is a passenger tire and needs to be derated by 10% for use on a trailer. You can also go with an ST tire of the same size and it will have a much higher rating.
                  1998 Wellcraft Eclipse 24 Cuddy
                  Volvo Penta Duo-Prop 7.4L "LK"
                  2006 Sun Tracker Party Barge 21
                  Mercury 90 4-Stroke FI
                  "Common sense is not very common"
                  "Failing to prepare is preparing to fail." -- John Wooden
