Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Trailer crossmember help
  • Trailer crossmember help
    I have an older shoreline trailer for a 19'boat
    The 2 crossmembers that the leafsprings and axel attach to are very rotted
    Im going to replace them
    They are both 8' long
    I can buy 3"x3" steel but should i get 1/8" steel or 1/4" thick?
    What condition is the rest of the trailer? Often when parts start rusting like that, the rest isn't far behind. Tubes rot from within.
    If you are going to replace the x-members, go with what's there now.
    BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      The rest if the tailer is pretty good
      The crossmemers arent the original ones looks like someone put them on from another trailer
      Im just worried about the crossmembers collapsing from being too thin
      The boat fully loaded is under 2000 lbs
      • #4
        get a new trailer. the rest of it will soon fail too.
        1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
        Past Boats
        1970 Wooster Hellion - Merc 9.8
        2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
        1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
        What’s behind you doesn’t matter.Enzo Ferrari
        • #5
          If a new(er) trailer just isn't in the cards-
          I like C channel, so I don't have to worry about what is going on where I can't see. I'd likely go 1/8".
          Old axles scare me too - because you can't see what's going on inside them either....
          • #6
            Ok thanks guys i didnt think 1/8" would handel the load
            Also my rollers have about 1/2" wobble in each direction
            Is that about right?
            • #7
              Depends on the roller
