Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
boat not sitting correctly on trailer?
  • boat not sitting correctly on trailer?
    Hello,
    I have a 2008 Chaparral SSi 190 on a LoadRite roller trailer that came with the boat. I am not the original owner. This is the second boat I've owned and trailered regularly.
    The rollers are all the way back at the transom. I use transom straps.
    Yesterday I noticed the boat bouncing up off the front rollers leaving the ramp. So I hooked up a video camera and went for a ride. Now this may be normal, but it seems that this boat is not sitting down properly on front set of rollers and is way too loose on the trailer.
    In this video I am leaving the driveway, you can see the boat floating over the forward rollers on the left side: https://www.youtube.com/watch?v=O_kIeHtX_dI
    And, when I took a 90 degree right turn on a bumpy road, the right side of the boat completely rose up off the rollers in what appears to me to be way too much. 15 second mark: https://www.youtube.com/watch?v=Rm3CzXt3_Wg
    I've always felt this boat seemed back heavy on the trailer.
    Can anyone provide any feedback on if this is normal? If not, how to correct? Thanks.
    Is the bow eye snug up against, and under the bow stop on the winch stand?
    What is the capacity of the trailer and what does the boat weigh?
    • #3
      Some boats bounce a bit depending on the balance point vs. the support points.
      Nothing outrageous in the video. Is the winch line under the bow stop? You could always do a tie-down line up at the bow. I had to do that with my 24 footer because the bow was a bit too bouncy for my preference.
      Best regards, Ted . . . . Cape Cod, MA
      Formula 330 Sun Sport, O'Day Mariner Sail #3224, Sunfish
      Past Boats: Catalina 22 Sail #10531, Formula 242 Sun Sport
      Twin Mercruiser 7.4 LX MPI (0F802036, 039), Bravo 3's (0F806198, 199), Mercury 7.5 HP (1969), Johnson 4.5 HP (1980)
      My Boating Web Pages: http://www.tpenfield.com
      Member of the Month - February 2013
      • #4
        2800 lb boat, 3600 lb capacity for the trailer.
        the bow eye is snug up to the bow stop. it isn't snug up underneath in that it would stop the bow the boat from lifting when going over bumps, but I can't imagine it should be that way anyway. my expectation is that the boat would be sitting with its full weight on the rollers and not be so quick to lift off the front set of rollers.
        • #5
          It shouldn't bounce like that. That's why some people swear against roller trailers because of damage to the hull.
          The boat is not strapped down tight enough. You need a bow tie down made of chain with a turnbuckle.
          2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
          2015 Yamaha FX Cruiser HO
          1984 Stingray SVB190SS & Mercruiser 3.0 Liter 140 & Evinrude 9.9 Kicker
          1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
          1960 Mulray 100 Dinghy, equipped with Beaver Oars
          1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
          68 Outboards: 1919-2017, representing 11 manufacturers
          Member ACBS, LBOA, AOMCI
          • #6
            If the bow eye is NOT against the stop (under it) it should be. Even if it is, when you crank the bow up it may be lifting the boat not off the rollers but unloading them considerably. Try lowering the bow stop so the bow eye still pulls up under it. Then try again. If there is no adjustment for the bow stop height, raise the rollers a bit. As it is, this boat is moving around way too much. Where it not for your stern tie-downs you may have dumped the boat on your 90 degree turn.
            • #7
              the bow eye is against the stop. its not going to stop the bow from lifting up - the eye is against the stop. it doesn't go under it.
              I wonder if you're on to something with the front rollers getting unloaded when the boat is pulled up snug to the bow stop. that seems to describe well what is happening.
              there is less than 4 inches left between the center line of the last roller and the transom.
              • #8
                Put up some pictures of the bow eye & winch area including the winch post.
                • #9
                  Wow that would have me nervous driving...my bow eye is up against the bow roller. I lock the winch right along with safety chain and transom straps. Interested to see the reason..be safe
                  • #10
                    this whole thing started because it caught my eye leaving the ramp, and I set up the video camera thinking I had one or two rollers needing adjustment. the hard right hand turn in the second video was me finding a place to turn around, I didn't do that because I thought the boat was going to do THAT! I did accelerate through the turn just to see if the boat would move. so when I got home and watched the video I was like "whoa, WTF?? I've been driving this thing all summer like this??!!"
                    fortunately the local ramp is 3 miles away, but I have done about 300 highway miles this summer.
                    • #11
                      Click image for larger version
                      Boy uploading photos to this forum really is frustrating
                      • #12
                        What happens as you winch the bow closer to the stop. Is the bow lifting? If so you are unloading the rollers. Lower the bow stop.
                        • #13
                          Can't crank it any closer to bow roller.
                          (Thinking out loud here Now if I lower the bow roller on the winch post that moves the boat backwards but lets the boat sit more heavily or solidly on the front set of rollers. I would then need to slide the back rollers backwards to sit as far back as they should. But can they be moved back? Not home to see. Hmmm...
                          • #14
                            More likely you'd be moving your whole winch post forward a little.
                            San Diego, CA "The 619"
                            "Nemo" (since Jul 2004): 1978 StarCraft 15' TriStar, 1978-88 "FrankenMotor" Mercury 70
                            Unnamed (since Dec 2016): 2000 Sea Hunt Triton 172 CC, 2014 Mercury OptiMax 125
                            "It's always easier to ask forgiveness than permission" -Colin Powell, et.al.
                            • #15
                              Of course. That will effectively shift rear rollers toward stern.
