I know most (if not all) transom savers require power tilt to lower the motor to a point where they hold each other firmly in place. I'm wondering if anyone has ever tried the following. I have a manual tilt Honda that has two shallow water tilt positions. If I were to raise the motor to the full tilt position (beyond the shallow water stops), then put the tilt/run lever to the run position and lower motor to a point that the transom saver supports the full weight of the motor, just above one of the shallow water stops and then put the tilt/run lever back to the tilt position. My thoughts are that if the transom saver ever were to break or fail in some way the motor could only drop down slightly before being held by the shallow water stops. Should this work or am I missing something? Thanks
