EZ Loader trailer with KNOTT bearing hubs
Status
Not open for further replies.
PatSea
I just bought a 13' Boston Whaler on a 2010 EZ Loader trailer. One of the bearings is rough and loud and needs to be replaced. I just found out the trailer hubs are made by KNOTT and are waterproof and are not intended to be greased or replaced. I
decee
I just purchased TWO 67BT EZ Loader trailers with said KNOTT sealed for life bearings. These trailers were manufactured in August 2022. I always like to carry spare bearings as I make long trips to remote areas. It is proving very difficult to find any part number for just the bearing as it is a unique beast.
And then I found this;
HUB KIT KNOTT HUB PD2750
  • KNOTT HUB FOR KNOTT AXLES SOLD WITH MAGIC TILT MT SERIES TRAILERS
  • SOLD EACH
  • IT IS NOT RECOMMENDED THAT THESE BE REPLACED ON YOUR AXLE.
  • THERE WAS A PROBLEM WITH THE SPINDLE SEAL SURFACE AND REPLACING
  • THE HUB WILL NOT BE A LONG TERM FIX
  • MANUFACTURE DOES NOT PROVIDE REPLACEMENT PARTS OR BEARINGS FOR THESE HUBS.
  • IT IS STRONGLY RECOMMENDED THAT THE AXLE ASSEMBLY BE REPLACED
  • THESE NEW AXLES WILL COME WITH NORMAL HUBS THAT CAN BE REPAIRED
  • USE PH1452 44″ FRAME PH1454 56″ FRAME
  • SEE KNOTT/KARAVAN TORSION AXLES FOR OTHER FRAME WIDTHS
Makes me worry a little about what I bought
Status
