I have free play in my Demco 66 surge brake actuator. By that i mean you can push the coupler back towards the trailer more than a 1/4 inch before encountering resistance. In the picture you can see the pencil line i made showing how far in it can be pushed. when you pull it all the way forward the stud that comes out of the master cylinder with the spring, plate and nut does not touch the brace on the coupler however when i depress the master cylinder piston i get a good shot of brake fluid when i open the valve, and the wheel can not be turned when its jacked up and the system is pumped up. Hook it to the car and pull forward 3 or 4 feet and hit the brakes and the trailer runs the full travel and bangs into the coupler like the brakes are not working. Thoughts?
