This is an 80's vintage EZ-Loader dual axle trailer. It seems like all similar EZ-Loader trailers are equipped with single axle surge brakes. Titan Model 10 Surge-A-Matic surge brake system.
Hauling it home from California, a steel brake line snapped next to the junction tee that feeds the left and right brakes. This did not seem to be a big deal at the time. I was wrong.
I bought a vacuum brake bleeder system so I could try to do it myself. I twisted real hard on the brake fluid cap. A 3/4" thin circular cap popped off under the stress. This reveals a 2/3" tall nipple with a 1/5" hole in the middle.
Tried and tried and tried to loosen the 1 1/8" plastic cap on the iron brake fluid cylinder. Squirting penetrating fluid at the base a 1/2 dozen times as well. No dice.
Without being able to loosen the fluid cylinder cap, I don't see how the vacuum pump can suck out the air and old fluid.
Got to be a trick that I am missing?
