As for the transom 'savers', those ones sticking from the trailer, They are good for engines that can't be locked rigid, like the any outboard without power trim or tilt, and Mercury's first power trim for outboards, the two rams hanging on the side power trim system. Those engines when fully tilted up by the hydraulics had to be tilted up a bit more by hand and a "tilt lock" was rotated 180 degrees and then the motor was let go. The motor was still free to bounce up and down. Here a bar from the lower unit to the trailer could hold the outboard steady. If the boat shifted on the trailer. there weren't any consequences as the motor could still move.
Using the Transom breakers with a motor that can be held rigid by hydraulics can place an enormous strain on the transom, if the boat were shift forward or backward on the trailer for whatever reason, an example, when the boat isn't jammed up against the bow roller, and shifts forward when the tow vehicle hits the brakes.
Making the motor unmovable in regards to the boat is good idea, attaching it to something separate from the boat maybe, maybe not.
The 'My Wedge' just lessens the angle where the engine is held compared to the stock Tilt lock lever. Looks like it would work on Mercs, but some OMC units required the rams to be fully retracted when trailering. Might not works so good there
It sounds like a solution to a problem that usually doesn't exist
