Jcris
- Apr 23, 2016
- 466
I recently replaced my old drum surge brake system with a surge disc brake setup. The tongue is removable which makes hooking up the reverse solenoid on the actuator problematic. The old system had a quick release fitting on the trailer side to allow removal of the tongue. Seems like removing that fitting each time will introduce air into the system and require bleeding the system very often. Whats the right way to make this connection?
