Thanks, It seems fine trailering, but I wasn't sure, the weight of the boat is on the trailer, and strapped in back, thanks for the advise.All depends on the trailer type and how the boat sits on the trailer. On some it supports weight but on other trailers it is just there during loading so the keel doesn't hit the frame. So once again it all depends??
Most of the time you don't want the boat touching the trailer bow rollers in the center section, except for loading. If there is a lot of weight on the center bow rollers after being loaded in place, it can make an indention or warp in the hull. So when the boat is properly loaded, the rollers should only be barely touching and no real weight applied on them for that reason. JMHO
