fibersport
- Jul 18, 2010
- 94
I have a Magnum Trailer which is a semi-custom trailer under my 84 Century Coronado, probably close to 5000 pounds or so. The current hydraulic actuator is an Attwood and not only needs all new internals but is also a bit bent where the actual coupler is. This unit is welded to the trailer so I will have to cut it out and weld in a new one. There is no real reason to stay with Attwood or any other brand, I would like some suggestions on which brand to go with. I have a Titan on my other boat trailer and it works just fine, the Attwood looks like a massive brute next to the Titan even though they are both rated the same. The Magnum trailer is a tandem with drum brakes on both axles, the Titan is on a single axle with discs (which requires the backing solenoid and wiring to back up lights). Any thoughts or suggestions?
