Alumarine
- Feb 22, 2005
- 3,684
Hi there.
I have an 18 ft. Sylvan on a bunk trailer that currently has a 3500 lb 4" drop axle.
The current axle is mounted on top of the leaf spring.
It's bent so I'll be replacing it.
I can get either a straight or drop axle for the same price.
Should I stick with the drop axle or is there some advantage to a straight?
Also, either axle will be 3" too narrow.
I plan on cutting it, machining an insert and welding it in..
Any gotcha's with that plan?
thanks
thanks
