I am replacing the hearings on my trailer and noticed there are small grooves inside the hub. Does the hub need to be replaced? And if so, how do you select the right size hub. Thanks
Are you replacing the races? Is that where the grooves are? As long as the grooves are just in the hubs and the races go in tight, there shouldn't be an issue.
BTW, you always replace races when you replace bearings.
