Hi!
I bought an older hoosier pontoon trailer for my pontoon. I believe it is a 2002. Anyways, its a double axel crank up trailer. I have used my neighbors crank up trailer for many years and never had a problem. My problem is last fall when I took the boat out of the water, I could not get the boat to go down while cranking it. It would not go up either. There seemed to be lots of slack in the other end where you hook it back onto the trailer. My neighbor was able to fix it with a large crowbar. Although, I'm not exactly sure what he did to fix it. Does anyone know what is causing this problem? I don't want to run into this problem again in the future.
Thanks!
Thanks!
