Got it done. Hub covers came off easily, they were EZ Lube axles and the hubs were fully packed with grease, so they came off easily and the spindles were good. Axles were galvanized and in good shape. Tossed the old hubs, bearings and all. Installed new galvanized hubs (no brakes) from E-trailer, reused old tab washers and spindle nuts. Packed the bearings first then pumped the hubs full after installation. Man, I like those zerks on the end of the spindles. Two old galvanized wheels were rusted through and wouldn't hold air. Had to remove all four hubs from the wheels though. Ended up drilling and grinding the studs from the backside and beating them through with a 3/8" punch pin and a 3# hammer. Got 2 new galvanized 14" wheels from Ecustomrim in Ft Myers (via Amazon) and had a local tire store remount the still-good tires.
Removing the old springs was as big a problem as the hub studs they were so rusted and frozen to the springs. Using a breaker bar and a six point 3/4" socket on the bolt side (the nuts were shot) I managed to either break off the nut or at least get the bolt to turn. Then I either cut off the opposite side with the grinder using a 1/16" wheel or I pounded out the old bolt. New springs from E-Trailer were then installed using 1/2" galvanized bolts from the hardware store, long enough that no threads were within the spring eye bushing. If this were destined to be a road trailer, I would have used 9/16" studs, but I couldn't find any that were galvanized. A new Zinc plated u-bolt kit with galvanized plate, also from E-trailer completed the install. Boy did those old u-bolts pop when cut with the grinder. The old fenders were so bad I just removed and tossed them as the trailer needn't be road legal. Glad I had my digital caliper to measure the spindle as I needed a different seal than the one that came with the hubs. Not sure why. E-Trailer had those too.
Finally I used up an entire spray can of Rustoleum Cold Galvanizing compound on everything either messed up by the grinder or not already hot dip galvanized: u-bolts, springs, wheel studs and nuts. That stuff is amazing. Altogether, I have less than $400 into the upgrade. A bit more than budgeted, but that is normal.
Trailer Idler Hub Assembly for 3,500-lb E-Z Lube Axles - 5 on 4-1/2 - Galvanized
| 4 | $123.16 |
-Leaf Double-Eye Spring for 3,500-lb Trailer Axles - 25-1/8" Long
| 4 | $79.96 |
CE Smith U-Bolt Kit for Mounting 3,500-lb, Round Trailer Axles - 5-1/8" Long U-Bolts - Zinc
| 2 | $53.90 |
Double Lip Seal for Marine Hubs
| 4 | $18.76 |
14"- 5 bolt rims (2) $65.62
Hardware, paint, grease gun and grease, tire mounting labor $70
