mckinney004
- Jan 26, 2016
- 46
I have an early 90s 28ft Harris pontoon on a Bobcat trailer that needs the bunks replaced. I recently found out first hand of the corrosiveness of pressure treated lumber with aluminum. So what should I be using for lumber for the new trailer bunks. Planning on using 2x6. Should I be buying untreated lumber and then coating it with spar varnish, oldtimers blend, epoxy, oil based paint, etc? I already have some PT 2x6 leftover from another project. Is it possible to coat it with something that would prevent the chemicals from reacting with aluminum?
As far as the coatings go, are any of the methods I mentioned any better than another. In addition to this project, I'm replacing two transoms in aluminum flat bottom boats. I'll be coating those as well with one of the methods. If they are all fairly equal quality, which is the most cost effective? It appears that oil based paint is by far the cheapest, however I'm not sure how long it will last if used alone. Or am I wrong?
