I lost the running lights on my trailer. 2001 Chevy Silverado. I check the plug and have about 1-2 volts. Find separate trailer running lights fuse blown. Replace 15A fuse, now have 7-8 volts at plug. Plug trailer lights in, fuse blows. Replace the fuse and all of the trailer wiring with new harness, reattach the new ground wire. Strong signal at plug about 8 volts. As soon as I plug the trailer lights into the plug, the fuse blows. Does this indicate a short in the truck harness? I checked continuity in my round to flat adapter, checked continuity on the truck plug with the harness disconnected. Could it be a bad trailer light? Uses a combo bulb for running and brake.
Thanks, domer
Thanks, domer
