1993 Seadoo SP Compression Test
philipp10
I picked up a very cheap 93 Seadoo SP last fall, had been sitting for 5 years. After messing around a bit, got it to start up and run. Took a compression test and got 120 in both cylinders. Many forums said at that level I should do a top end rebuild. So I tore it apart and replaced gaskets and rings etc. The cylinders looked great, gave them a hone and threw it back together. Also replaced the oil hoses (which was a good thing as they were pretty rough). So I ran it about 2 hours so far this summer and it does run well. Re-took the compression again (it was cold) and got only 120 psi. Supposed to be closer to 145. Do I need to warm it up first? Or is my gage bad?
Jeff Walkowiak
120 was just fine you did not need to tear down the ski, more importantly the cylinders are even. I bet your gauge is a bit off but forgetaboutit , go ride the ski and don't mess with it.
