'95 Yamaha Waverunner III GP Fuel Starvation
starflt1701
Last year my Waverunner started acting at times like it was starving for fuel. It would stumble coming out of turns when accelerating, and on a warm start would run for a few seconds and then die, requiring choking to start it again.
I changed the fuel filter and rebuilt the carb with a Makuni kit. The ski runs better, but the warm restart issue remains. It acts as though the fuel system is depressurizing after a short while, and when restarted, runs only on the fuel remaining in the line between the filter and carb.
Can anyone recommend the likely causes I should investigate?
I had thought about proactively changing the fuel lines with 1/4", but read recently that the return line from the carb to the fuel tank is a special hose with a built in restricter. Is this true? If so, are there any other hidden surprises in other lines I should know about that would preclude replacing the line with generic 1/4" fuel hose?
Thanks.
