Cueball876
- Aug 5, 2014
- 11
So my boat ran fine the other day, went to start it today and no spark... I go thru my ignition testing, ohming my stator.... I get normal reading yellow to yellow(red stator), but no reading from green/white to white/green.....output voltage was down around 45 volts.... Stafford bad right? So I pull my flywheel, I find about half the magnets stuck to the stator with the other half stuck to various parts of the powerhead....is this what caused my stator to go bad? Can anyone give me some part numbers that cross reference for the flywheel.... Seems the force flywheels are much cheaper but I want to make sure they will fit. Should I replace the regulator as well?
