Hi. I have a 2000 kawasaki zxi 1100 That won't run past 3500rpm. I was told there's some sort of safe mode. I have completely rebuilt the motor due to low compression in the front cylinder. Installed a new starter, relay, and regulator rectifier, I also made sure ALL the connections were clean throughout the entire wiring harness. I disconnected the water temp sensor and the air temp sensor. To see if that would fix the issue. But it's still doing the same thing. Is there anything else I can check ?
