ohiojetskigirl
- Apr 28, 2014
- 1
Hello, I am in some help! My 760 is over heating. Symptoms I know of that is different from my other jetski same make and model/year as this one.
It ran fine then out of nowhere the temp gage starting going off. If I keep it under 25 or 30 mph it doesnt seem to come on. But after a few minutes of faster speed it comes on. Let it set for a bit and its fine until I go over 30mph or so and it repeats.
The side where the water comes out (from the pee spout) isnt a steady stream. Its like it spits quickly but not steady stream. Like its being interrupted. My other ski flows with no interruption. As well the water that does come out it alot hotter than the water that comes out of the good running ski. Not sure if that's relevant by there is a big difference in their temps.
I have been told it could be alot of different things and am hoping someone on here maybe able to guide me on how to start checking on what all it could be.
Also does this particular make and model have a thermostat? If yes do you know where its located?
Thank you so much!!!
